Im buying new fencing, was going for closeboard, but now looking into hit n miss panels just to be different! They do them in vertical and horizontal style. Are they as strong as the closeboard panels? The horizontal style only have two rails.
Bear in mind that with vertical 'hit & miss' fence panels, when viewed from a certain angle you might be able to see through the fence into your neighbours garden. And vice versa, unless the boards overlap sufficiently.
But they probably stand up to the wind better than a solid panel.
