Ferroli 901 not firing
19 Dec 2009
Wont fire unless u blow into clear tube from aps. Fan is working ok. Metal cover that covers fan chamber the gasket is split. Any ideas?
Does the chamber that houses the fan need to be pressurised?
your boiler would be classed by a Registered Gas Engineer as I.D
this means Immediately Dangerous
please turn it off and have it repaired by a Gas Safe Engineer
There isnt a gas leak. Bgas have been round and replaced pcb worked 4 a few hrs. It must be an aps problem lack of air flow or pressure
Get Bgas back, the risk to your family is not worth the risk of having a go yourself.
or correctly working safety device
how do you know there isn't a gas leak Byron? and Its not methane you should be worrying about
Seconded !!
