Hi, I live in a flat approx 10 years old, with a ferroli domina 102 boiler. I believe it hss been here since the flat was bulit but only lived here 9 months.
I am a complete novice with all things gas and central heating. For this reason attempted to get boiler cover, but the company I used don't cover my boiler, I am now therefore attempting to see if there are some easy solutions to try before calling out a plumber.
Have noticed this evening that despite the thermostat calling for heat, the boiler is not firing up, or even doing anything to acknowledge the call for heat. (Water pressure ok, no flashing lights or red lock out light present). I have changed thermostat batteries but this has not made a difference. Tried simply resetting, again no change. Hot water is working when hot tap switched on.
Only thing worth noting is that my bathroom towel warmer radiator has been leaking, this was a tiny tiny amount, so have tightened the nuts yet the leak has got worse! (Have definitely tightened them as turning other way makes water run out freely!). Will this radiator be effecting the CH? I am tempted to call plumber, just wanted advice of any things I need to try first.
Thanks.
Thanks.
