We moved into a house with a Ferroli boiler two years ago. The diverter valve has leaked twice (split) and therefore has been replaced twice. It's happening again as it's just started leaking.
I believe that the water pressure may be causing this (according to the last guy who replaced it). Does anyone know if this is a common problem with this boiler? And is it a case of fitting a Pressure Reducing Valve to the cold water supply that feeds the boiler?
We don't seem to have undue high pressure, but maybe I need to check this?
I'm aware that Ferroli boilers are not great by the way.
