Fiesta Encore 1.3 1997 Screen Washer Problem
1 Nov 2007
Lincolnshire
Last week my screen washer was working fine, now when I push the button in (for the front), or pull the lever towards me fully (for the back), the wipers move, but no screen wash comes out, I can't hear the motor working either.
Is this an actual motor problem which will involve it being replaced? Or is it fixable?
if the fuses are ok sounds as if the motor has gone,quite easy to replace,best to check power at pump connector first with multimeter to see if you have 12 volts there to eliminte switch or wiring
The pumps cost literally a few quid and usually just push into position. As CH says, check for a voltage at the multi plug before buying a new motor
