fingerprint from Evo-Stik Polyurethane Wood Adhesive
5 Jan 2006
Hi
I've used "Evo-Stik Polyurethane Wood Adhesive 310ml" for wood fixing.
I have a couple of finger print marks on the wood from where I was handling this during the work.
Is there anything that would be able to be used to clean off the fingerprints??
if it's still wet, acetone (nail varnish remover) or warm soapy water.
If it's hardened you'll have to sand it off physically.
It's water soluble, so may wash off, but will raise the grain and require sanding back.
Polyurethane glue water soluble? PU glues react with water to set, so how can that be? Are you perhaps confusing the product with Resin W PVA?
