my boiler fires up ok but i cant get any heating or hot water.....when i try the hot water i get hot water for a few seconds then it goes cold...would this happen if the pump has gone? can anyone help?
check pressure guage on boiler is showing 1 bar, if not ,top up system pressure. If pressure ok, pump needs checking. see if there is 230 volts at terminals, if there is and pump wont run......... its knackerd
