You have a flat which only has one lighting circuit.
It presently has a consumer unit with fuses.
You are going to upgrade the consumer unit to dual RCD. (or maybe RCBO)
It is not practical to split the lighting circuit into two.
I do not want the flat to be in complete darkness when a bulb blows, (as this causes the MCB to trip).
This is making things less safe from a certain perspective.
How do you stop a bulb blowing, tripping the MCB ?
All options considered.
Would fitting a Type C or D MCB not trip when a bulb blows ?
Surly this would still trip quicker than a fuse ?
Why does an RCBO require an earth connection when an RCD & MCB don't ?
