Flitch Beam Plates
11 Apr 2012
Looking for some advise
I need to buy plates for flitch beams (3 Plates at 225mm x 8mm x 5300mm drilled for M12 Bolts.)
Can anyone advise where I could buy these from in the Birmingham area?
any steel suppliers would do the steel then drill it yourself ( work up in size and use oil)
I got mine from hyten and then drilled the holes myself
but bear in mind it will weigh about 75kg each so they could deliver straight from there suppliers to your door for less
