Flue proximity to window.
Discussion in 'Plumbing and Central Heating' started by MaverickJesus, 2 Apr 2012.
  1. MaverickJesus
    2 Apr 2012
    6
    Thanks Received:
    Gloucestershire
    Country:
    I have recently had an Alpha HE25 safety checked, and the engineer informed me that whilst the boiler itself was perfectly fine, the flue had been installed within 300mm of the top left corner of the kitchen window, and so it had failed, and suggested that even though he couldn't force me to not use the boiler, if I did he recommended I keep the kitchen windows shut for safety (which I have).
    My question is, what solutions are there to rectify this? I'm close to finishing the decorating and want to get moved in asap - can the flue be 'extended' to make the gases expel outside of the 30mm limit, or does the flue need to be completely moved?
    Many thanks.
  2. Agile
    26 Jun 2004
    61,246
    Thanks Received:
    4,281
    London
    Country:
    30 mm is very close and must have been fitted by an unregistered.
    It all depends on the layout inside and outside and boiler model what could e done.
    A photo would help!
    Tony
  3. MaverickJesus
    2 Apr 2012
    6
    Thanks Received:
    Gloucestershire
    Country:
    As requested
    [​IMG]
    [​IMG]
    The more work I do on this house the more my catalogue of DIY Bodge Job/Hall of Shame increases in size with evidence of the previous owners misdemeanour's - I'll save that for a different thread though :D
  4. 45yearsagasman
    14 Mar 2010
    5,891
    Thanks Received:
    1,035
    Norfolk
    Country:
    Its a shame he didn't us a vertical flue kit and took it straight up. That may be an option even now, but would be costly. There may be a plume management kit available for your boiler and that would extend the flue outlet up and away from the window. You would have to check with Alpha.
  5. boabcelt
    27 Jun 2008
    980
    Thanks Received:
    265
    Fife
    Country:
    I would say thats a lot more than 30mm from the window :confused: The appliance instructions will give guidance on flue terminations.
  6. MaverickJesus
    2 Apr 2012
    6
    Thanks Received:
    Gloucestershire
    Country:
    Thats probably because I misspelt in the main post, it should say 300mm :eek:
  7. boabcelt
    27 Jun 2008
    980
    Thanks Received:
    265
    Fife
    Country:
    The manufacturers instructions stipulate that a 300mm distance from windows is preferred but that the terminal can be within 25mm without impacting on the appliance operation. They recommend 300mm to avoid issues surrounding condensation pluming.
  8. MaverickJesus
    2 Apr 2012
    6
    Thanks Received:
    Gloucestershire
    Country:
    Really?
    So was it valid for the engineer to whack a big red sticker on the side of the boiler saying it was dangerous and shouldn't be used? I'm not au fait on Gas regulations so I'm a bit in the dark on this...
  9. Whitespirit66
    15 Dec 2007
    8,011
    Thanks Received:
    753
    Bristol
    Country:
  10. peekay53
    22 May 2011
    668
    Thanks Received:
    95
    Merseyside
    Country:
    i hate to keep harping back to this but the flue position is wrong according to MIs so why do ppl insist on saying use a plume kit the plume kit is for avoiding nusiance caused by pluming.IT is not a way round MIs and regs regarding position of flues in regard to openings in buildings
    peekay53
    • Thanks Thanks x 1
  11. peekay53
    22 May 2011
    668
    Thanks Received:
    95
    Merseyside
    Country:
    boabcelt no one is doubting the that there will be no impact on appliance operation and if the aforementioned window did not open but the window is openable and so pocs could be coming back into an opening in building
    contravening the MIs so how can you say ok thats fine
    peekay53
  12. peekay53
    22 May 2011
    668
    Thanks Received:
    95
    Merseyside
    Country:
    and yes maverickjesus he was quite right to put a big red sticker on your boiler and you should be grateful to him for doing it because it may well make you think before you open that window and allow pocs back into your property
    peekay53
  13. MaverickJesus
    2 Apr 2012
    6
    Thanks Received:
    Gloucestershire
    Country:
    Which is exactly why I got it safety tested in the first place ;)
  14. peekay53
    22 May 2011
    668
    Thanks Received:
    95
    Merseyside
    Country:
    by the way what was the recommendation of the engineer who advised you flue position was incorrect did he not say how best to get over this problem.Seems to me he was ideally placed to find a soluton having been on site and able to weigh up alternatives
    peekay53
  15. MaverickJesus
    2 Apr 2012
    6
    Thanks Received:
    Gloucestershire
    Country:
    He told me to replace literally everything, including the 'works fine' boiler, which is why I sought more opinions. I've never used this engineer before as it is a new area, so I don't have a trusted guy to work with (yet).
Loading...
Share This Page
