Hello, experts:
Our Vaillant EcoTech Plus boiler, with a part-central heating system, has been installed for three years, and we had it serviced this year, for the first time. Everything was said to be OK.
Recently, for the first time in all of the three years, I set the DHW to a higher temperature, as, in cold weather, it was not hot enough for a bath, and I had plucked up the courage to tinker with the settings (believe me, when I did this, I was terrified of upsetting the system in some way). When the engineer installed this boiler, he said that he was capping its capacity (how, I don’t know, of course), because there are only three radiators and DHW to serve, and there was no need for its full capacity to be enabled. Since then, when I leave a message for this engineer, I have found it impossible to get any reply from him. (I think that he must be more interested in installation jobs, than servicing work.) The man that serviced it this year was a newcomer. However...
I find that the DHW setting cannot be increased beyond 65° and, though this is better than it was, it still is not as hot as I would like it —not even after running it for a couple of minutes. Is there any way to increase the DHW beyond this point? Is the top limit of 65° a result of the deliberate reduction in capacity? I have looked in the manual, and I think that, if Comfort Mode were enabled, this might allow me to increase the DHW above 65°, but I am not sure. Also, the manual makes reference to a cylinder that, if Comfort Mode were enabled, would be kept at a fixed temperature (which cylinder, I take to be inside the boiler, since we have no cylinder for water anywhere on the premises). Reading the manual makes me dizzy!
However, even if there is a cylinder in the boiler (if there were, it would surprise me), there is mention of risk of Legionella bugs being encouraged.
In the manual, there also is a reference to VUI/VUW boilers. I have no idea whatsoever whether our boiler is either of these types, or another type altogether.
So, my questions, for anyone helpful enough to offer advice, are:
1) Can the DHW be set to a temperature higher than 65°, by any means whatever?
2) How can Comfort mode be enabled, and, in view of the risk of infections being harboured, would it be worth doing this?
3) Is this boiler one of the VII or VUW types, and what do these terms mean, anyway?
4) Would it be in any way detrimental to have the boiler set to its full capacity (i.e. as if there were a house-full of radiators)?
With thanks in advance, for helpful comments etc.,
A.W.
A.W.
