ford focus 1.6 diesel 2007 reg central locking problem
20 Sep 2014
Kent
hi everyone, am in desperate need of help. my central locking on my ford wont open all doors even though there is a click in all doors when i open with the key fob. the driver door opens but the rest wont open not even from the inside can some one help me i don't know what to do. please i need help
If the drivers door work as it should, check in the black boot between the drivers door and the car for broken wires. If the drivers door has issues, it may well be your fob or fob/car connection, battery.
Are you sure the click is coming from each door ............
You can use this to check you own problems against the thread
http://www.focusfanatics.com/forum/showthread.php?t=133249
Hi Mursal yes i here the click sound from all doors but wont open. i have sent it to a mechanic he diagnose it and he said it was coming up as can bus error but he said he couldnt do it because if he does the key fob needs to be reprogrammed which he cant do. he suggested someone but cant get hold of the person
http://www.focusfanatics.com/forum/showthread.php?t=133249[/QUOTE]
