- Joined
- 26 Oct 2015
- Messages
- 24
- Reaction score
- 0
- Country
Hi. I'm terracing my garden, which slopes steeply up from the house.The diggers have just removed the heavy clay soil from the area in front of the house. This leaves a rectangle 10 x 9 metres, the back of which is a clay cliff 6 feet high, in front of which I have to build a retaining wall. I'll probably use hollow concrete blocks with rebars through them and in the footings, with a land drain behind the wall on gravel, with gravel above it. I've been told the concrete foundation should be at least a foot thick because of the clay and the height of the wall. My problem is that the cliff is already collapsing here and there and I don'r want to make it worse by digging a foot deep trench in front of the cliff, to make it almost 7 feet high. There will, however, be a raised bed in front of the wall along its whole length apart from the steps in the middle. The raised bed will be about two feet high and two feet deep. My question is whether I could build the footings in the shallow trench already in place and raise them above the ground level and patio level, to make them a foot thick. They will be hidden and covered by the raised bed. Is this feasible if I use rebars in the footings to strengthen them?
