FRIDGE FREEZING
Make sure the fast freeze switch has not been pressed accidently (if it has one). It is for freezing new food and the compressor runs continuously.
Need more info , model etc, had that problem with my Samsung American side by side F/freezer.Was a design fault which I managed to sort out eventually.
your door may have dropped, meaning the seal isn't air tight on the door anymore so the cold air is escaping too fast making the compressor cycle more to keep the internal temp down and making the moisture ( which is getting in via the bad door seal ) freeze to the wall / drain hole..
check the bottom hinge point is tight and that your door bushes aren't worn too badly..
