Hi all we have just moved into a new house and our boiler has started playing up.
It does it when the boiler is cold (ie not been run for an hour or to, in a morning or if out at work all day).
If i run the hot tap the boiler will lock out, I'll go in the loft and reset and run the hot water again itll lock out again. But if i reset and put the heating on it will fire as normal and work, and ill be able to use hot water too.
