Grant vortex 26 combi oil boiler
24 Dec 2012
Norwich
Hi
last time no hot water but heating ok
I tried to descale the dhw heat exchanger but ended up buying a new one
anyway we have some hot water now but not all the time.
It seems ok when heating on but warmish othrer times , the boiler does not seem to keep up to temp and will fire if tap turned on any ideas
skelo
Hi
skelo
Plate heat exchanger must have been bad if it needed a new one.
Sounds like the diverter valve isn't working properly.
The boiler should fire when tap is turned on.
It may not have a diverter valve, depends on the age of the boiler. If you have two pumps, is the hot water pump working?
It has 2 pumps and a new plate heat exchanger , central heating ok and fine but boiler seems to be idle and not heating up water all the time could it be the sensor or thermostat maybe ?
ta
steve
If it's the one with the braided metal/rubber hoses from the pumps they will be blocked stopping the boiler water getting to the plate from the h/ex.
