Gravity Fed Hot Water System
7 Mar 2004
I have an old gravity fed hot water system and am unable to control the temperature of the hot water. Is there anything that I can fit to the system to enable me to regulate the temperature? :?: :(
THIS DOESN"T APPLY IF YOU HAVE SOILD FUEL!!!!
You can add a 2 port valve in the flow pipe from the boiler and control it using a thermostat on the cylinder. The supply to the boiler should be taken from the output (normally orange) from the valve.
