Greenstar 28i Junior Fault - Hot Water but No Heating !!!
Discussion in 'Plumbing and Central Heating' started by dmbeale, 17 Mar 2012.
  1. dmbeale
    17 Mar 2012
    3
    Thanks Received:
    Kent
    Country:
    Hi everyone,
    We have a Worcester 28i Junior Combi which developed a fault this week. We have hot water fine but no heating. This same fault developed when we first moved into the house 2 years ago, it was the heat exchanger. (The boiler had not been used for at least 6 months before that as was an empty property) Replaced by British Gas for £99 plus min 12 homecare package. All been fine since. However the batteries died on the wireless room stat last week and since then have had no heating.
    I dont know whether this is just a coincidence or linked to the fault, as although the batteries have been replaced and the clock working ok on it, nothing from the boiler. Does the room start have to be "paired" to the boiler again ? any suggestion on procedure ?
    The only time we can get any heating is if we press the "spanner" maintenance button for 10+ seconds and it fires into life with red hot heating for less than half an hour... then shuts down again !!!!
    Spoke to BG, explaining the situation (we cancelled the contract last summer as all was fine and were having new pipework installed throughout house so no heating at all obviously needed over the summer), advised new contract £22 pm as known fault plus one off repair cost £100 approx
    Any other suggestions or advice gratefully received before i make another investment to them!!!
    Regards
    Dave
    Maidstone, Kent
  2. manofgas
    22 Jul 2010
    16
    Thanks Received:
    4
    Country:
    sounds more than likely that the wireless thermostat is out of sync with the receiver,best option would be to try to locate instructions for the controller from the manufacturer's web site
    • Thanks Thanks x 1
  3. middlesbrough
    14 May 2009
    4,794
    Thanks Received:
    487
    Middlesbrough
    Country:
    Check your instruction for the rf , it may need repairing .
    There was also a similar fault explained on here few days back regarding the diverter valve which was an easy fix should it end up being that.
    Try the rf stat instructions first make sure there paired up.
    • Thanks Thanks x 1
  4. dmbeale
    17 Mar 2012
    3
    Thanks Received:
    Kent
    Country:
    Thanks for the advice guys. I did look around a few forums and found that an un-paired room thermostat seems to be a common problem.
    I managed to download the user instructions book direct from the worcester-bosch site and followed their instructions to pair it up.... SUCCESS !!!
    New batteries in (old batteries found in drawer made clock tick but not enough to send signal to boiler!) and it paired straight away.. and the boiler kicked back to life instantly... rads warming up nicely !
    Thanks again
    Dave
    :p
  5. Agile
    26 Jun 2004
    61,347
    Thanks Received:
    4,286
    London
    Country:
    That is the only repair that does not need an engineer!
    RF stats need very good batteries and I always advise Durocell.
    Tony
    • Thanks Thanks x 1
  6. dmbeale
    17 Mar 2012
    3
    Thanks Received:
    Kent
    Country:
    Cheers Tony,
    Could not agree more ! New set of duracell plus fitted today so fingers crossed for 6+ months trouble free.
    Dave
Loading...
Share This Page
