I have tried everything but though i would ask the forum for help!
Last night i tried bleeding the radiators but did not turn off the pump or CH beforehand. I now realise my mistake!!
This afternoon i noticed the pump was making a wooshing sound as though air was rushing through the pipes with the water. I have tried turning the pump off and have drained all the air from the sytem using the bleeding valves on the radiators and the pump itself. There is no air in the system - only water that is clear now comes out.
The wormglow boiler will now not start even through there is pressure in the sytem as the expansion tank beside the pump says 1 bar. I can not heat the CH or HW.
The pump is still making a whining noise and it does not matter what setting i put it on - 1,2, or 3. The pump gets hotter than the pipes when i turn it on but i have checked the motor is turning by taking out the bleed screw and turned the motor with a screwdriver.
Is the pumb knackered or is there air still trapped in the system?
Can someone please help as it is freezing!!!
