guest house
31 Oct 2010
Fife
how does guest houses and hotels run miltiple toilets when not against outside walls so theres always away to do it even if you need to run internal soil stacks i take it thats costly
does that meen theres always a way to do it even although it could be costly does pipe then go underground
All the services in hotels ect are (normally) carefully planned with ducts built into the fabric of the building to solve problems of noise, concealing of pipes ect, the stacks run in these ducts and then run underground.
what about putting internal stacks in 2 storey property connecting 4 en suite shower rms to outside soil stack if joists dont favour run
Didn't you say in another thread you had 5 Saniflos? What a racket that lot will make all night.
its 4 saniflos i need to get rid of them even i need to get internal stack built hope someone will come up with ideas even at great expence surely theres away i think joists are in my favour so hopefully go outside even if new stack outside does joists run the same way on each floor i know the loft runs way i like
How high are the ceilings ? is there enough room to drop the ceilings and run the soil pipes in the void to the outside.
ceilings are very high good idea does that sound like best optionwould need a good builder and plumber i suppose
