- Joined
- 31 Aug 2016
- Messages
- 8
- Reaction score
- 0
- Country
Hi
I've googled extensively for this with no luck.
I'm redoing the bathroom, with the bath/shower against the external (215 mm solid brick) wall. At the same time, I'm redoing the other external walls in the house with 60mm PIR backed plasterboard.
I want the same thermal effect in the bathroom, but i'm loathe to use insulated plasterboard here as I've read that cement board/aqua panel/marmox is generally better than tanking. So I'd like to put 60mm PIR board with cement board on top.
So my question is: how best to secure the aquapanel/hardie on top of the insulation board?
I'll be using dot n dab with mechanical fixings for the other walls.
Some methods I've thought are:
- super long pre rawled screws through cement board and insulating board into wall. Downside: vapour layer compromised.
- batten wall with 3x2, put PIR blocks in between, screw hardie board into battens.
Downside: cutting PIR means more chance of vapour being behind; cold bridges at battens.
- batten wall, then insulating foam and hardie board screwed into it. Downside: wall is now coming 10cm into room....
Any help appreciated!
