Heater fan no blow.
4 Feb 2011
Devon
The heater fan on my Rover stopped blowing and I have traced the fault to the thermal cutout. My question: What temperature thermal fuse should I use and how many amps should it be?
It should be possible to cross reference the part number from the likes of Maplins or RS, but purely at a guess I'd say 10A and 100deg c.
John :)
Thanks John. You were very close. My choice was a 120c 250v 10amp fuse (£1)so I got the amps right. The old cutout was a bi-metal affair that had badly corroded, but luckily the wire wound resistances had survived. Replaced the cutout with the new fuse and all 3 fan speeds are back and work as advertised. I got quite cold last winter.
