This one is driving me mad. I'm no plumber, but I'm trying to work through the logic - can you help?
So, my heating only comes only when the tank thermostat (+ timer + room thermostat) are on.
The pump is working fine as is the boiler. The timer seems to be doing it's job as does the room thermostat.
I have come to the conclusion that this is likely to be a problem with the motorised valve in the airing cupboard.
Is there anything I can do to test my theory?
If it does turn out to be this item - is it a wholesale change of the valve, or are parts of it user servicable?
Appreciate any advice you can give me. Many Thanks, Steve
