heating works but no hot water Heatslave 18/25. Help!
If boiler is running for CH, your problem is nothing to do with running out of oil. If you cannot follow the fault finding chart, then you will need to consult a professional.
thanks Oilhead. I can't find the fault finding chart for this boiler. Any ideas? I could then try to follow it...
sorry to be dim Terrywookfit, but how do I do that? thx
It's under the control panel . Should have a removable plastic cover over the reset button.
Download the manual for location.
The manual reset would isolate the burner. As the burner is working, then I doubt this is a problem. When I have encountered this problem, it is either the diverter head (the horrible Drayton) or a faulty programmer.
