I am going to instal an integrated Hotpoint washer dryer under a worktop which has 870mm of height available.
The height of the machine can be adjusted to between 815 and 835mm by screwing the feet. the 150mm plinth will fit in front. However there are bars and extra feet supplied which can be bolted to the underneath of the washer to raise the height to between 835 to 870mm. It does not appear to require fixing to the underside of the worktop as there are no fixing points.
Increasing the height will. I presume, mean the plinth height will need adjusting.
My question is does the washer need, for some reason, to be raised to the 870mm height or can I, hopefully, leave it. As it is integrated the washer will be concealed behind a kitchen unit door.
Thanks. David
Thanks. David
