So I had the engineer code, which was 4 digits then 0, on my 9751 alarm and I changed the settings on the alarm so the user code was 6 digits as oppose to 4. But now the engineer code does not work. Any ideas as to what the engineer code would have changed too?
Spot on, Cheers.
Don't suppose you know how to set up the chime facility do you? I know how to turn it on and off but not sure how to set it up in the first place
