Help finding a MCB...
29 Dec 2006
London
As some of you may know I am fitting a new electric shower.
I am looking for a 40A MCB.
Unfortunately I can’t find one the same size. I’ve tried Screwfix, B&Q Wickes and local electrical shops...
Does it have to be the same overall size as long as the rear connection is the same?
Any help/advice appreciated.
Possibly obsolete now. Try e-bay for a second hand one. I had the same problem with my old MEM consumer unit. Found some on e-bay no problem.
Adam_151 said:
I trust you are aware that you are most likely doing notifiable work?
This is from my Council:
PART P BUILDING NOTICE –
ELECTRICAL WORK ONLY
£246.75 :eek: :eek: :eek: For a new shower??!!
Anyone know how to get it done cheaper?
dingbat said:
You'll have a job. That's a BS 3871 circuit breaker, the standard for which became obsolete in 1991.
While that is true, it doesn't automatically rule out the possibly of finding a new breaker for the board, of course the new breaker will be a BSEN 60898 type, the issue here is that crabtree have changed the design of the boards since the OP's was installed. I know that for example, you can have an old hager board with BS3871 breakers, and fit brand new hager BSEN 60898 breakers alongside :)
Mind you, it would make things easier if the standard did govern the fitting and connection... ;)
Cheers all.
Should have tried the net first, would have saved myself a few miles today searching different shops!
