Help needed please - Gledhill Pulsacoil III system
11 Dec 2009
London
Hello all
DIY novice here with no knowledge of hot water systems so I would really appreciate any advice you can give on my situation, which is as follows:
1. I like in a block of flats which all have the Gledhill Pulsacoil III system installed. It has worked like clockwork for the 5 years I have lived here (or so I thought). I believe the system is 10 yrs old.
2. I noticed that the water level in the Feed and Expansion tank started dropping below a certain level which resulted in the boiler not heating the water. A residents forum advised that in such circumstances the F&E tank should simply be topped up. When topped up the system seemed to work fine again.
3. In my stupidity, I went along with this for about a year, periodically toping up the F&E tank without having regard to any underlying problems. Eventually I paid Gledhil Response a fixed fee for a call out and guaranteed repair. However, they told me that the cylinder itself was leaking and would need to be replaced.
4. There is evidence of rusting at the bottom of the cylinder and clear evidence of one or both of the immersions leaking. However, I was unsure how Gledhill could be certain that the leak was from the cylinder itself, and not just from the immersions.
5. I got a second opinion and a engineer who has dealt with these systems in my building said it was most likely that the immersions were leaking. He also suggested that it was not uncommon for Gledhill to jump to the "you need a whole new boiler" suggestion.
6. Gledhill advise me that they will change the immersions at my own risk if I want them to. Alternatively, they will replace the whole system with either a Pulsacoil BP or a PulsaCoil A Class ECO appliance. I have been quoted £1,300 (inc vat) for this. Given that the existing Pulsacoil II has been leaking for some time now, the bottom of the cylinder is quite rusted so my preference would be to get a new system fitted for peace of mind. However, I obviously don't want to throw money down the drain unnecessarily.
7. I'm not sure whether the price of £1300 price is good value or not but I'm concerned that Gledhill might increase the cost mid-project on the basis that the replacement of the system may require some joinery work or new piping. I have asked them to confirm whether they think this will be necessary in advance so I have more certainty as to what the final cost will be.
So essentially, my questions are as follows:
1. Does anyone have any experience of the Pulsacoil III system and its reliability. This will help me to decide whether to get a new one or just repair it.
2. Does nayone have any views on the Pulsacoil BP or PulsaCoil A Class ECO appliances and whether £1,300 is a good price to pay for a replacement with either of those two models. Is one much more reliable than the other?
3. I have seen on other posts in this forum some quite strong (negative) opinions against Gledhill which causes me concern. Could anyone shed any light on why this company attracts such critism.
Any help would be very gratefully received.
I've had almost an identical problem, the system is looking rusted now and I'm looking to get it replaced.
Did you have any joy in finding out a reasonable cost?
I almost just feel like running the unit into the ground until it just stops all together, but being my luck it will be winter then and the prices will surely shoot up...!
They wanted 60p a minute to talk to their tech line when I phoned, *******s to them, I wont be using their stuff.
Hi Guys
I have replaced many of these at one development in Canary wharf where the units were about 10yrs old. Due to the initial design and installation they do not have any drain or relief pipework so an unvented cyliner is out of the question.
I eventually installed 10 Gledhill torrent cylinders which everyone appears to be happy with in terms of performance.
I have attached a link to a specialist Pulsacoil repair web page which has excellent info on your range. I am not in anyway linked to this site just found it years ago when I was looking for options on these rotting thermal stores.
http://www.pulsacoil-repairs.co.uk/pulsacoil-3.html
Pete
OP here. Not been on for a while so apologies for the delay.
I eventually got Gledhill to replace my Pulsacoil II with a Boilermate BP (mainly due to a lack of options and running out of time). The total cost came to around £1,300 plus a one year call out parts and labour service warranty. I'm not sure but I understood this to be a fairly good price because I got the cylinder at trade price (or so I was told).
Overall, the installers did a decent job (although scratched my wood floors in the process). I now have the security of having a new boiler although I'm sure I wuold have been able to get a better one for maybe a lower price if I had hunted round more.
