I HAVE BEEN HAVING PROBLEMS WITH MY BOILER FOR APPROX 3 MONTHS I HAVE A POTTERTON 80e AND WAS INSTALLED 17.6.97 AS FAR AS I AM AWARE ITS LAST SERVICE WAS 2 YEARS AGO.
MY PROBLEM STARTED WITH THE BOILER CUTTING OUT WITH A RED WARNING LIGHT SAYING LOW SYSTEM PRESSURE I TRIED TURNING IT ON AND OFF A FEW TIMES AND IT CAME BACK ON.THIS HAPPENED A FEW TIMES BEFORE I CALLED SOMEONE OUT THEY INFORMED ME THAT THE PRESSURE SWITCH WAS BROKE THEY REPLACED IT AND CLEANED OUT THE PIPES.AFTER APPROX 1 WEEK THE SAME LIGHT KEPT COMING ON AND WOULD NOT GO OFF BY JUST TURNING IT ALL OFF AND ON AGAIN.I THEN TRIED TURNING IT ALL OFF AND AT THE SIDE OF THE BOILER IS A VALVE I TURNED THAT AND IT MAKES A HISSING NOISE AS THOUGH IT IS RELEASING PRESSURE AND THEN TURNED IT BACK AGAIN. I TURNED ON THE BOILER AND IT ALL WORKS AGAIN. I HAVE BEEN DOING THIS FOR ABOUT A MONTH NOW.
THE HEATING WATER ETC HAS ALL BEEN FINE UNTIL LAST FEW DAYS THE DOWN STAIRS RADIATORS HAVE NOT BEEN HEATING UP properley AND HAVE NOTICED THERE IS WATER LEAKING FROM SOME OF THE PIPES UNDER THE BOILER.
I HAVE HAD SOMEONE LOOK AT IT AND HE SAYS THAT THERE IS LOTS OF ISSUES AND THAT I SHOULD LOOK TO GET A NEW BOILER I HAVE ALSO SPOKE TO THE LAD WHO WHO CAME 1ST AND HE SEEMS TO THINK IT JUST NEEDS A GOOD CLEAN AND SERVICE AND SOMEBODY ELSE HAS SAID IT COULD BE SOMETHING ELSE.AS YOU CAN TELL I HAVE NOT GOT A CLUE ABOUT BOILERS AND IF ANYONE HAS HAD THESE PROBLEMS OR CAN GIVE ME SOME ADVICE I WOULD BE SO greatful AS I dont KNOW WHAT TO DO.................... THANKS
