Hiding cable
Discussion in 'Electrics UK' started by masona, 22 Jan 2012.
  1. masona
    5 Jan 2003
    12,878
    Thanks Received:
    125
    Essex
    Country:
    I understand you cannot hide cable, eg 2.5mm T&E behind the skirting board but is it okay to put it on front of the skirting board in a trunking? I'm confused as you can buy a mould trunking that goes on top of the skirting board but isn't that a hidden danger? Can't see what's the difference if it's behind or hidden in front :confused: If not, then I can go another route but it's a lot more work
    [​IMG]
  2. Taylortwocities
    28 Jul 2006
    16,101
    Thanks Received:
    1,550
    Oxfordshire
    Country:
    If it is in trunking you can put it in front of or on top of the skirting board. But not behind it!
    You can see where the cable is when in trunking so you can put wherever you like - diagonally across a wall, if you must.
    Things only get tricky when the cable is concealed.
    • Thanks Thanks x 1
  3. JohnW2
    28 Jan 2011
    30,576
    Thanks Received:
    1,947
    Buckinghamshire
    Country:
    Life came before theories - it is theory which is so unlike life :)
    Kind Regards, John.
  4. sparkwright
    20 Aug 2009
    5,742
    Thanks Received:
    666
    Dorset
    Country:
    The difference is if it's behind the skirting board you cannot see it, if it's in front and made to blend in you can still see it.
    • Thanks Thanks x 1
  5. JohnW2
    28 Jan 2011
    30,576
    Thanks Received:
    1,947
    Buckinghamshire
    Country:
    Reg-wise, yes. In the real world, it can also get tricky if the trunking is aesthetically so 'good' that it may effectively 'conceal' the existance of the cables, by looking to some people as a plastic skirting (or plastic part of skirting). I know of a case in which someone drilled into one (to attach a phone socket or somesuch), not realising that it was cable trunking!
    Kind Regards, John.
    • Thanks Thanks x 1
  6. RF Lighting
    31 Mar 2006
    18,917
    Thanks Received:
    1,183
    Leeds
    Country:
    Use D line quarter round trunking. fit it where your skirting meets the floor and you'll hardly notice it at all.
    [​IMG]
    • Thanks Thanks x 1
  7. masona
    5 Jan 2003
    12,878
    Thanks Received:
    125
    Essex
    Country:
    This is why I'm surprised it's acceptable!
  8. masona
    5 Jan 2003
    12,878
    Thanks Received:
    125
    Essex
    Country:
    I'm wondering if it's possible to put a metal conduit inside the trunking? Not sure what's available
  9. Taylortwocities
    28 Jul 2006
    16,101
    Thanks Received:
    1,550
    Oxfordshire
    Country:
    Now you are being silly.
    Why not just have a length of thick black steel armoured cable running around the floor of your room. That would look so smart. But just think how much safer it would be.
    Trunking is a perfectly acceptable method of cable installation. Some concrete construction flats have even beed rewired in the stuff. Just get on with it, any further discussion is pointless.
    • Thanks Thanks x 1
  10. ban-all-sheds
    27 Aug 2003
    57,042
    Thanks Received:
    2,305
    London
    Country:
    Masona has a point.
    In theory it may be in trunking, but to all intents and purposes, in real life if you have an unnoticeable moulding atop the skirting, particularly if you paint them both, you have a situation no different from a cable behind the skirting.
  11. Monkeh
    25 Jan 2010
    4,149
    Thanks Received:
    329
    Cornwall
    Country:
    Tap it with a knuckle. Anyone who drills straight into something without knowing what it is is dumb enough to drill into a safe zone, too.
  12. ban-all-sheds
    27 Aug 2003
    57,042
    Thanks Received:
    2,305
    London
    Country:
    Tap a thin bit of skirting loosely attached to a wall in a place where there's empty air behind it.
  13. JohnW2
    28 Jan 2011
    30,576
    Thanks Received:
    1,947
    Buckinghamshire
    Country:
    I've told you of the case I saw. The perpetrator knew that it was hollow plastic, but thought it was plastic skirting - so he drilled (very small) pilot holes into it for self-tappings screws (I think to attach a telephone socket) - and hit something other than plastic :)
    Kind Regards, John.
  14. Monkeh
    25 Jan 2010
    4,149
    Thanks Received:
    329
    Cornwall
    Country:
    I have. It sounds and feels totally different to a bit of uPVC.
  15. Monkeh
    25 Jan 2010
    4,149
    Thanks Received:
    329
    Cornwall
    Country:
    Then look for the seam or see if there's some actual wooden skirting under it. He'd probably drill into dado trunking thinking the sockets were just mounted on it. Common sense goes a long way.
    Never heard of natural selection? This is how it works.
Loading...
Share This Page
