Hoover washing machine model AS110 problem
25 Nov 2005
It does few ani clock wise spines and it stops and does not run any more what is the likely cause? I have just fitted a new motor brush; the drum was not rotating before that.
I had a problem with the door prior to this issue. It was not open, it open with a bit fiddling, but I am not sure if it locks
Yes it starts filling with water
it fills up to the usual amount of water then stops filling
then nothing?
you could try checking the motor first with a multi meter, just to make sure. then move onto the pressure switch then controller pcb
theres videos on how to test these components on the likes of espares website
no error code I take it.
No error code,
Can you please email me the website you mentioned to run the diagnostic test
