hot water in header tank
28 Jan 2008
Gloucestershire
Hi
I have a baxi backboiler and as soon as it comes on water flows through the header tank, the water soon gets warmer and warmer,causing a lot of dampness in the cupboard,could the problem be a faulty honeywell control valve.
Is it pumping over? If so may be a blockage (if on a cross vented "h" system) but i am guessing as limited info posted
sorry about info i dont no if it is a vented "h" system , boiler is a baxi bermuda 552 and it does flow into the tank as soon as the pump starts it does sound like a blockage, i had some radiators changed downstairs last year what do i need to do to unblock it please
Hi if its pumping over and the tank is geting hot i can be becauase the pump is set to high for your type of sytem and depends where the cold feed is going into the system and the head of water on the pump
just try turning the pump down to number 1 and check it then before you look for any blockages anywhere
mick
mick
thanks mick but have already checked the pump and it is on number 1 its an old system with 8mm micro bore any other ideas please
