- Joined
- 1 Feb 2005
- Messages
- 63
- Reaction score
- 0
- Country
I need to plan how to get a hot (and cold) water supply to a small WC with sink and to a room that will eventually be the kitchen.
This isnt an issue right now except that I am re-fitting the bathroom and one option is to run the supply through this room, in which case I want to do it before plastering and tiling.
The WC is about 9m, and the Kitchen sink 10-11m (by the shortest routes) from a WB Combi and I am worried that this will mean a long delay before getting any hot water? Groundless fear or reasonable worry?
IF instead I run a cold supply only to the kitchen and use a little gas powered instantaneous water heater (there is a suitable external wall for the flu though it is over 600mm thick which might be an issue for some flues maybe?) then the WC is only 2 meters away (straight above).
IF I go with the instantaneous gas heater, what size/power would be reasonable and are they any good or am I setting myself up for a world of misery?
