hotpoint ultima dwf-60 update - more help needed please
fay
11 Feb 2007
Nottingham
hi
i have a hotpoint ultima dwf - 60, it has been in the garage for a couple of mth while we moved house, we plumbed it in today and switched it on and got error code F.
water is going to the machine from the pipes but the machine isn't filling up, just making a humming noise (like its trying to work) and not filling up.
any help would be great, thank you!!
:D
Inlet valve faulty or locked out due to blockage would be my guess.
thank you for your reply!!!
will get my partner to look into that.
thanks
:D
we have checked the inlet valve (had a plumber out he was usless) that seems to be ok.
some told us that if the machine has been moved it sometimes closes the valve up to stop it from leaking or something, does anyone know how to open the valve back up, is it electrics?
thanks
:D
yes tried there, all they say when you cakl them is we're not aload to give that information over the phone you have to call an engineer out.
can't really afford that.
but thanks anyway!
sent an email a couple of days ago, but thought i'd post on here incase anyone knew anything in the mean time.
Moderator's note:
No need to create a duplicate thread. I have coped your latest post below
Mod Rupert
fay said:
i have posted on here about a poss valve but looking into it more someone has said my problem maybe because the dishwasher was moved and the vavle shut down (if thats the word) to stop its self from leaking, and may just need rebooting?? is there a button or something! i have no idea!!
cheers
What did the plumber check? That water comes out of the tap? Did he take the inlet valve out and disconnect it from the machine to test it?
It's either got a blockage which has locked out the valve, a faulty valve or if it was transported on it's side, a stuck pressure switch.
