Similar problem to brenny with an F05 fault on hotpoint a washing m/c aquarius WMF740 7Kg. It won't drain.
Didn't want to hijack brenny's post (//www.diynot.com/forums/viewtopic.php?t=254030), so a new one.
The front panel at the bottom comes away and I've had off the filter cap, as in brenny's post.
All clear in there for me. No nylon stocking!
There looks to be a small impeller, which turns quite freely, and all entry/exit pipes I can get to from there seem clear.
I've removed the pipe feeding to the sink waste. All clear there. No pennies or anything stuck in the end.
The waste pipe joins from the top and seems well fitted, so won't have the problem of sink waste flowing into it.
Bit at a loss now.
Machine only 3 months old, so warranty shouldn't be a problem, but if it's a simple blockage somewhere, don't want to be stung for a callout without checking basics.
Had a look at the back, and where the grey waste pipe comes out, doesn't look like I can get at anything there easily.
Any other suggestions?
Bit at a loss now.
