Hotpoint WD420 Aquarius
4 Feb 2011
Fife
This machjine has started to leak from the inlet on the powder tray during a spin cycle. The water spews from the large pipe connecting the tray to the drum. Its not so bad on a slow spin but on fast spin its time to clean the kitchen floor again !!
The pipes look ok however I was trying to locate a filter and cant :?:
any ideas welcome
thanks
Remove rear White cover and you will see a black cup with a jubilee clip round it Remove and clear rubbish
Thanks for the info. Now that I've done that can you advise on the location of the outlet hose from the powder tray. There is a small diameter plastic tube and a rather larger outlet fitting. Is this right or am I trying to connect to the wrong fitting.
Thanks in advance for your assistance
Wot u mean from the sump at the back. the outlet tube from the dispenser is at the front.
At the back of the dispenser there is a clear tube that travels around the side of the drum to the ball filter connection at the bottom. On the dispenser itself there is a fitting and a circular red connection block. The tubing diameter looks too small for the fitting and the clip to attach it is also too small. I am finding it a bit confusing
That clear tube fits on the stalk of the red presure switch. It is a tight fit. It the goes to the White chamber on the sump there's a stalk it goes on to again a tight fit
Many thanks for the info. I should've paid attention when disconnecting the tube but it is all back together now and the first wash is in.
Cant thank you enough :D
