hotpoint wd420
30 Jan 2013
Wiltshire
Hi i wonder if anyone can help me? my hotpoint wd420 has just started playing up. I put it on a k program which is a 30 quick wash and it filled with water and now will not do anymore than that. If i put it on drain or fast spin it works fine but not on a normal wash?? some assistance would be much appreciated :D
I have been trying different cycles, when i put it on a k wash which is a fast 30 wash after a while the wash light is flashing slowly?
Put it on rinse and spin does water enter.
i tried it on rinse and spin and no water, just does its little spin cycle. Ive got a feeling it may be the valve???
Yes but it's a 2 or 3 way valve. The whole valve needs replacing.
thank you very very much, the water pipe has two connectors on the back ive looked on ebay but cant seem to find a double cold water inlet?
It depends on the serial no and com code of the mc. There's 3 diff versions of valve. If you got a continuity tester see which one is open curcuit.
ive just taken it all apart and im going to go to a shop tomorrow and hopefully get a complete replacement. Thank you very much for your help
I usually just pull off the faulty solenoid coil and push a replacement one in its place. You can buy a universal type single valve to get the new coil but you would need to cut off the original wiring plug and fit female spade terminals.
