hi i want to add a radiator in my garage to my existing system, can i run from another radiator or should i tee in to the in feed and out flow 22mm and could you tell me where the flows are best located..cheers.
Thanks a lot for a quick response Kevplumb If i come from above down to the rad should i take 22mm as close to the rad as poss or can i use 15mm straight to flow and return..
Flow and returns usually located under upstairs floorboards.
Run your new feed from them to your new rad.
You can tee off another rad if it is fed from a single 15 mm feed branch off the F & R and your system is up to it.
Well spotted by Masona.
You should fit isolating valves so that they can be turned off before they exit into very cold places.
Comes under energy conservation.
BCOs will cut your legs off if they inspect your job
