How do I mend holes in wood?
OM2
18 Jan 2007
I have a kitchen cabinet that the door has come off.
What's happened is tha the screw fixings in the wood have somehow worn the wood and won't go back in properly because the holes are too big now.
What can I do?
Can I simply use filler?
And then when dry, drill new holes?
I wasn't sure if this would be a good idea.
Surely the filing would be prone to coming out much much more quickly with wear and tear and general use of the cabinet door?
Any help/pointers would be appreciated.
Thanks.
OM
You can buy hole and plug cutter sets. You drill a hole with cutter, cut a plug from similar wood using plug cutter, glue plug in hole.
Alternatively, buy some dowel and a few mm bigger than the hole needing repairing, drill out the hole to the size of the dowel, glue and length of dowel in and cut off flush.
Potentially not as accurate as the plug cutter option, but effective it done with care.
Problem with dowels is you are screwing into end grain.
i tried searching on ebay.
couldnt find any results.
what search terms should i be looking for?
I have yet to come across an epoxy anything that is like steel. It is like epoxy, a plastics material.
ok... maybe not like steel... but will it do the job i need doing?
will it replace my holes?
What wrong Jasonb link idea?
This is how it's done below if you're not sure,
You can buy the plug cutter sets from a company called Tool Station, you can find them online or order by phone with a catalogue. The web site is www.toolstation.co.uk and the number is 0808 100 7-2-11.
Plug Cutter Set £5.35 64444
Titanium Plug Cutter Set £9.94 72650
The numbers after each item are the order codes to save you time.
Good look from your trusty cabinet maker phil
couldnt find anything for 'hinge repair' on ebay.
what should i be searching for?
