Ok in the interest of getting to the bottom if this one and keeping the moderator sweet, can I start again. This is the situation to recap - alarm was activated from PIR, pass code could not be entered to turn off so I popped fuse out then disconnected battery. On Re-powering found the panel to be locked.
Whether I attach mains first or battery first I still cannot activate the key pad.
The only advice which I have yet to try and which is also given in the manual is to disconnect the AUX DC POWER, STROBE AND BELLS INC.S.A. MODULE and this applies to initial power up and at any other time when power has been lost.
However nowhere in the manual can I find instructions on what to do when the alarm has been disabled due to an activation. Can I assume this is the same advice?
I attach the gospel according to Scantronic for the avoidance of any doubt
