How do I take this tap apart to replace the washer?
Discussion in 'Plumbing and Central Heating' started by briony10, 19 Mar 2012.
  1. briony10
    1 Mar 2012
    13
    Thanks Received:
    Country:
    My upstairs bathroom tap was dripping and stupidly I put off the job as a plumber is coming next week to do a big job on the house so I didn't want to call him out separately.
    Now the tap is running constantly and won't turn off. There are two shut-off valves: one 'in-line' one under the basin and a tap downstairs which turns off the water to the upstairs. I have a downstairs bathroom as well so I thought I could get by until the plumber comes.
    Well it is typical that neither of those shut-off valves is working! :rolleyes:
    I have changed the inside of a tap before by unscrewing the cover which said 'hot' and just undoing a screw. Unfortunately I cannot see how to undo this tap, the ceramic thing on the top does not seem to lever or screw off. Please can anyone help? I do realise it would be better to call a plumber but I would like to try myself if possible.
    Thanks for any advice.
    [​IMG][/url]
  2. 45yearsagasman
    14 Mar 2010
    5,893
    Thanks Received:
    1,036
    Norfolk
    Country:
    Turn off the water supply to the tap.
    Use a spanner on the hex part of the main body, and while holding the spout firmly, undo the main body anti clockwise and remove the tap innards.
    There is no need to remove the tap handle.
  3. briony10
    1 Mar 2012
    13
    Thanks Received:
    Country:
    Thanks, I will give it a shot but it is a pity it is not as simple as the tap I did before. Everything seems to be seized up, so I might not be strong enough.
    For a constantly running tap is it usually the washer or the unit inside the tap that needs replacing?
  4. 45yearsagasman
    14 Mar 2010
    5,893
    Thanks Received:
    1,036
    Norfolk
    Country:
    Normally a damaged washer, or if you are really unlucky the valve seating may be pitted. In that case the tap would require reseating. A plumber would fix that in 10 mins, so that may be your best bet.
  5. briony10
    1 Mar 2012
    13
    Thanks Received:
    Country:
    Thanks, I had to find my adjustable spanner thing and got it undone. I replaced the washer and it stopped the continuous running. I will get the plumber to re-do it properly when he is here next week, though. I feel like I might have missed something important.
    Thanks ever so much for the help. I wouldn't have known how to undo the tap. :D
Loading...
Share This Page
