How to fit a shower pump....?
29 Sep 2005
London
Hi there,
I have just fitted my new bath suite and the water pressure is fine apart from the shower.
Can anyone give me an idiots guide to fitting a shower pump!
Any help would be greatly appreciated.
:confused:
The short answer is no - it isn't a v simple job. Several things to consider.
Hi atjhza
I have fitted a shower pump no problem, I got one with push fit connections, just simply cut out and Tee'd off the existing pipes whilst running it via the shower pump...
Main things to consider is there is enough water or it will draw too much out, and that the tanks are big enough or they will get drained.
http://www.mirashowers.com/onlinecatalog/pdf/enduro.pdf
Here is Mira's Instructions which are pretty good.
diybristol said:
I have fitted a shower pump no problem, just simply cut out and Tee'd off the existing pipes
Which is precisely what you can't do with a shower pump....
ok thats what i did and it worked ok and still doesso why not tell us how to do it in a positive way?
