I about to insulate our 1960s leanto before installing a new kitchen. The walls are being rendered and tanking solution applied. I need a minimum of 25mm insulation. As far as i can tell i have 2 options:
1. dot and dab
2. Studwork
I'm trying to find out which option is best for this situation. The walls are brick but not entirely even and there will cupboards mounted on the wall which makes me think that studwork with insulation between the studs is probably the best approach. Is this right?
(I should probably add that i'm keen to keep the depth to a minimum so as to save on room space).
1. dot and dab
2. Studwork
