How to remove Hotpoint WM63 washing machine motor?
20 May 2012
Dear all,
this is first time for me and need some expert advice on how to remove the motor in hotpiont wm63 washing machine?
any help would be use full.
thank
Why do you need to remove it. If you are changing the brushes it can be done in situ.
thanks for reply.
already changed brushes but it keep on tripping our RCB and now I guess the motor needs replacing, I also smell buring plastic near motor.
thanks
You can unplug motor and see if it trips. It you want to remove it remove the bolt at the back of the drum. Then slip belt off then swing motor up , then remove 2 lower 13 mm bolts.
