I am looking to install this light to the rear of my property at some point this weekend, but need to know whether it is a straight forward task:
http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=101495&ts=07354&id=51942#
There is no access to the lighting circuit indoors, and the CU has no RCD protection at all. I can supply power from a ring mains socket in one of the bedrooms fairly easily. Drill right through and connect the light with the wire not having any run on the external wall at all. Seems fairly trivial but I'm aware I need a FCU with 3A at some point. Plus Im aware I need some sort of RCD protection.
What's the best way of doing this if these are the only options I have to play with, is this work notifiable???
Thanks guys
Thanks guys
