How to wire in parallel motion light sensor and push button
gcs
26 Nov 2013
I need to control lighting on the stairs by motion sensor and by push button with timer. Can anyone provide me with a circuit diagram for such a wiring.
Thx
What do you mean by regualtions? Standards? Nothing specific, sometimes we follow the IEC standard and oher times we refer to the French code. I just need to know how we can connect motion sensor and push button with timer to the same circuit. And in case the light was ON by the motion sensor and someone pushed the button does the timer override the lighting motion sensor?
Push button timer will have a set time for lighting to stay on, motion sensor may have in-built time setting, they should all be wired from the same circuit,
i would expect which ever has the longest time setting, to override the other, dependant on when each one detected motion or button pressed.
Does anyone have a circuit diagram or schematic diagram for such a wiring and what should I connect to the circuit breaker such as contactors...
