How would I make this swedish ripoff?
28 May 2012
Surrey
Hello all
So we like the look of a certain piece of furniture in Ikea but they dont make it in the right size for us.
It doesn't look too tricky to make but its where to get the materials. The internal bits are easy but where do you get 50mm thick 2500mm long gloss white bits?
I've done a quick sketchup of what I'm after, ideally it would be all gloss white, but the top really needs to be.
Cheers for any help
Lee
are you going to make it out of mdf and paint it, or are you hoping that it will look presentable if you make it out of white Contiboard or similar?
(it won't)
I'm guessing conti board would be ok for the internal structure, but I was hope to get something premade for the chunky outside sections. Painted MDF, can that ever look good?
Wickes sell a 3000m gloss white plint but its £580!!!!!! Maybe a gloss white worktop cut to size? But I can't find one of those thats at least 2500mm x 390mm
It doesn't really need to be 50mm but I was hoping for something more than the bog standard 15/18mm.
Easy to make, if you have a suitably equipped multi million pound production factory workshop like Ikea, without it ,no chance, the sides are 50mm low density chipboard , with laquered high gloss paint finish, not something you can buy off the shelf. :unsure:
Hi Lee
I suppose the answer is that anything looks simple until you have to do it. To my mind there are two different approaches to make this item in gloss white, and neither of the, include the use of Contiboard! Whatever else to make something like this you will need to be able to cut many, many components extremely accurately, both into parallel strips and into exact same lengths. Can you do this?
In terms of materials there are two different approaches which spring to mind; firstly make the entire structure out of MDF then spray finish to a high gloss, the second is to make the entire structure out of high gloss white MF-MDF (melamine-faced MDF). The sprayed MDF approach is only really feasible if you have access to spraying facilities - or somebody who can spray to the appropriate standard (and BTW car sprayers don't always excel at spraying MDF). The MF-MDF technique involves you in being able to make a large number of absolutely chip free cuts - something which very few powered hand saws can achieve (the exceptions being the guide rail saws sold by Festool, Makita, Mafell, etc). Manufacturers of high-gloss white MR-MDF include Polyrey and Finsa - although I would caution you that the standard sheets are about 3 metres x 2 metres and weigh somewhere in the region of 80 to 90kg. If you are lucky you might find someone who can supply the white in 8 x 4 ft - I know of only one firm in my area who can do this. Standard thicknesses are normally 18mm with a few places selling 8mm. You will rarely find anyone in the trade who is prepared to break this down into smaller components - because this stuff goes to the shop fitting (manufacturing) trade who obviously won't pay for anything they can do cheaper themselves!
In terms of 50mm thick, I think you may have to compromise a little, but a suitable thick edge material could be made by sandwiching a layer of 12mm MDF between two 18mm layers of high gloss white (giving 48mm) and they edge banding the result with a colour core laminate
There is always the possibility of getting a CNC house to supply and machine the materials for you (there are 2 or 3 in the home counties I know of), but that will considerably increase the cost. Were I doing something like this I might consider compromising and buying two IKEA units, cannibalising to get the parts I needed then building my own frame round the outside and getting it professionally sprayed.
Easy to make, if you have a suitably equipped multi million pound production factory workshop like Ikea......
I was thinking more decent panel saw, carcass cramp and edge bander - not multi-million and more like the sort of thing a lot of manufacturing shopfitters actually use. Still wouldn't see much change out of £10k secondhand (new think £35k).
Why not use two layers of 13mm white melamine board with 22mm mdf sandwiched in between and a 50mm iron on edge to finish off?
:idea:
Edit.
J and K got there first. :mrgreen:
By the time the op gets himself tooled up for this it will be far cheaper to buy the ikea version.
you could also make it out of mdf. glue and pin it together. rub caulk into all the joints to hide the cut edges. Hand paint with eggshell or satinwood. The top needs a superlative finish, people won't notice the rest. If you make up a cutting list your DIY shed might cut to size for 50p a cut, and will be pretty good.
I did a very similar thing a few years back in my first home and money was tight. You can make the lot out of MDF, the uprights being continuous from top to bottom fixed with screws in the ends and individual shelf's on supports between. A diagonal brace or 2 on the rear or fixed back to the wall to prevent the whole thing falling over. One of the sheds will cut it perfectly if they have measurements. With careful attention spraying could yield a good finish though mine was brush painted and looked OK, you will never be able to take it with you though given the size/weight.
No need for any specialist tools.
Really though I would have just shoved 3 Billy's together which near enough gets you the right size and if you really wanted some extra uprights got it in white and had some contiboard cut up for the uprights.
edit: BTW most of the sheds won't stock MDF longer than 2.4m!
Thanks all for your posts, I've managed to talk the wife into getting a worktop that matches the kitchen and am going to hack two units together.
Cheers again for the advise
I think I have a similar "challenge", and I propose to make the 50mm from a sandwich of five longitudinal 40 x 20 battens between two sheets of 5mm ply, with stop-ends from the same batten stuff. Mine only needs to be painted.
STOP it sounds too complicated ,whats wrong with18mm mdf and 45mm lipping and just have the illusion of thick sides have you heard the acronym kiss great design motto
Ah. Mine has to span 950mm, so the full depth gives greater strength/less bending. Only the front batten has to be exact, and the ply top & bottom.
