A pal of mine has a Hyundai Atoz and is replacing his semi auto box with a normal gearbox as his semi auto box has bit the dust. He has bought a replacement box and all the bits to go with it such as clutch pedal box, gear lever etc. He was also given two cables (why two?). Has anyone done this conversion on a Hyundai? Any major problems/snags? Where can He get a manual for same car? What other car is the Atoz based on? Something I have just considered is the crankshaft to flywheel connection. Does the crankshaft have the flywheel holes to enable flywheel to be bolted on? Will the input shaft fit into the crankshaft? Where can he get a manual? Any info will be appreciated no matter how small. Cheers.
