I haven't used my Immersion heater for a fair while & only there for back up so I may not even use it, However :
I want to replace the "flex" from the switch to the Immersion heater in the Airing cupboard.
Is 2.5mm 3 core Heat resistant cable OK for this ? Is there any maximum length & can this rest on the circumference of the insulated hot water tank ?
There was lots a few months back about checking the thermo-stat operation on immersion heaters, I intend to turn mine down to the minimum setting & is a test OK to let it heat up & see how warm the tank gets (& pipes) and observe the LED on the consumer unit (to know when it has turned itself off ?).............also of course go up into the loft & ensure the cold water tank is infact "cold".
Thanks,
Paul
Thanks,
Paul
