Indesit Dishwasher d41 error codes
27 Dec 2006
Surrey
Does anyone have the error codes for Indesit D41 slimline dishwasher - it is not completing the cycle (although dishes appear clean) and flashing rinse light remains on.
In that case it's a heat related problem. Either thermistor, heater, both or wiring problem.
Hi, what if it's the second light from the left flashing? Gets all the dishes wet, and drains but doesn't 'wash' as such... any help much appreciated, thank you!
I know this thread has been inactive for a long time, but I couldn't find the answer to the question about light 2 flashing on a d41 indesit slimline dishwasher anywhere else online, so I rang the company. Maybe posting this here will stop other people having to spend ten minutes on hold!
If light 2 is flashing on it's own, (that's the second light from the left, third from the right, underneath the symbol meaning "wash") this means that the solenoid valve is faulty or that there is a heater fault, but most likely the first, according to the person on the Indesit helpline. They couldn't/wouldn't tell me anything more than this.
About the solenoid valve: http://www.ehow.co.uk/about_6310115_dishwasher-solenoid-valve-failure.html
It's a heater fault. But can you run a cleaner though it first it means its all scaled up if that don't work then new heater req.
Hi
I have a INDESIT dl450 and at the end of the cycle it flashing led 3 and 5. Does anyone know what this means? Many thanks.
